跳转到主内容
2015年三月发布的MacBook 11吋使用第五代intel i5/i7处理器,並且拥有比前代稍佳的性能与电池寿命。
140 个问题 查看全部
Keyboard Replacement, is there a repair guide?
My son spilled a soft drink on his computer. Keys are sticky to the point you can’t use the keyboard. I’m looking to replace the keyboard. I can purchase a new keyboard for around $20 but I don’t see a repair guide showing how to do the replacement. I do see an upper case is available but it’s like $125 and it’s a long multi step process but still doesn’t cover replacing the keyboard .
I read one post that states the keyboard is riveted to the case. I’m up for a multi step process to get this laptop working again, but not so sure I can tackle replacing broken rivets.
Has anyone replaced the keyboard and or do you have a step by step repair like the ones found on this wonderful site?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Here’s the replacement keyboard, cost $25.55 + a couple of hours screwing:
https://www.amazon.com/Odyson-Keyboard-A...
Here’s the guide for doing it:
https://www.youtube.com/watch?v=knI4Bgd7...
这个答案有帮助吗?
得分 3
添加一条评论
Yes, but you must replace the upper case with it: MacBook Air 11" Early 2015 Upper Case Replacement , it will cost $139.99 with: MacBook Air 11" (Mid 2013-Early 2015) Upper Case and yes you have to do the long complicated process, that is how Apple works
MacBook Air 11" (Mid 2013-Early 2015) Upper Case图片
产品
$99.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ross Chambliss 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 11
总计 214
