跳转到主内容
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
How to fix broken spring contact on Display assembly?
I was putting my iPhone 3GS back together, and snagged one of the 2 spring contact on the bottom/backside of the display assembly, just before closing the case. It snapped right off. :( Now, I am trying to determine if I buy a replacement display assembly, whether it will have the contact assembly with new contacts? I'm assuming that these supply the power to the display assembly???
Please help, as I can't find a back side picture detailing whether the parts will work or not.
Thanks,
Matt
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
i believe you mean the 2 prongs of the home button? they are the only 2 prongs I can think of on the back of the display. Check and see if your home button works..if it doesn't then you'll need to purchase a new flex which are pretty cheap to buy. unfortunately it'll mean following a guide to remove the digitiser to get to the home button. Once that is done the replacement is straightforward..there is only one hole in the midframe for the flex to pass through. you will just need to use the double sided adhesive tape to stick the flex on to the home button and on to the back of the midframe.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Matt A 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 923
