跳转到主内容
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
Can I add a SSD and keep the current hard drive?
I want to have 2 storage devices, in other words.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Here’s the guide for installing an SSD 2.5” drive.
Installing iMac Intel 21.5" EMC 2428 Dual Drive Kit
You can then use the optical bay for an additional standard drive.
@danj shows how to do that here:
Configuring a dual drive setup
这个答案有帮助吗?
得分 3
添加一条评论
Hi David
Technically it is possible, one way is to sacrifice your optical drive and get a optical drive to sata bracket converter to fit your sata drive.
这个答案有帮助吗?
得分 1
1条评论:
Do keep in mind the optical drives SATA port is slower! SATA II (3.0 Gb/s) Vs SATA III (6.0 Gb/s)
Using the dual drive kit is better.
完成的
添加一条评论
添加你的答案
David Nichols 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 88
