跳转到主内容
Beats Solo 2 Wireless headphones are a wireless version of the Beats Solo 2. Released in 2014. Model number: MHNG2AM/A.
48 个问题 查看全部
No screw holding inner carapace
I am trying to repair a pair of beats solo 2, as no sound was coming out of the right side. I’ve seen that this is a common problem, but when I opened them up I noticed that it did not have a screw on the inner carapace underneath the tape. It is instead held together with what appears to be 2 white pieces with a slit in the middle. Does anybody know how to take that apart?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Please show us what step on the guide you are referencing:
Beats Solo 2 Wireless Teardown
这个答案有帮助吗?
得分 0
2条评论:
Its not a battery problem, it is the other side of the carapace part connected to the other side of the battery (the part with the rubber parts you need to push through)
完成的
I also have this problem. There is no screw that I can see. The tear down above does not help.
完成的
添加一条评论
添加你的答案
Adam Remaly 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 6
总计 105
