Broken Rear Glass, Swapping The Full Housing?
I have an iPhone X, space grey, 256gb. I’m sure some others have the same problem I am having with replacing the rear glass. That being said, I know the easier way to fix this is swapping the full housing. I am looking into doing the project and found a site where they sell the full housing and everything is already mounted up. I guess it’s a used iPhone X and maybe the motherboard was messed up. If I buy this, are only my motherboard and Face ID sensors needed to be swapped over or are there other parts that will need to be swapped as well?
2条评论
How did the back cover turn out? I'm looking to buy a similar product from the same seller.
由 chris jordan 完成的
I never got around to buying it but I did do more research and found that the only components you have to switch over are the Front Camera, Logic Board, and the screen. Everything else can stay in the phone. So, what I would very highly recommend is to buy one with the battery, taptic engine, and all the other components already in the phone. This is less of a mess and a lot easier to do. Instead of a 3-5 hour job, it could be a 30 minute to 1 hour job. Something like this posting here: https://www.ebay.com/itm/100-Authentic-A...
由 Spencer Draper 完成的
