跳转到主内容
Support and repair information for the Xiaomi Mi Band fitness tracker.
I Can t charge my device
My device is amazfit pace 2 and i cant charge it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
Please elaborate your issue, why you are unable to charge it. Do you have the charger for this device.
完成的
Yes but i tried with other chargers and original but i cant charge the device
完成的
Yes, Also I have this issue. How to charge it
完成的
I have already gave the solution. Please check for dirt accumulation on the connector point of Fitness Tracker & charger. Try cleaning it with rubbing alcohol & pointed tooth-stick (please don’t use any metal object). Once cleaning is done try charging your device; hope this should solve the issue.
完成的
添加一条评论
1个答案
There are two contact points on MI band and the charger, clean these points with some alcohol (hand sanitizer), use earbud or small cotton ball. Please let me know if this fixes your issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Pietro Berton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 570
