跳转到主内容
加入维修社区 - 创建账户
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
My fusion drive has split.
My fusion drive shows as 2 drives and when I try to repair it through disk utility, I get the following error message: BTW I have installed MacOS on the HDD and left the SSD empty. It runs very slowly.
Kevins-iMac:~ kevinheath$ diskutil resetFusion
Internally-located hardware disk device known to the currently-running macOS:
Rotational                               (disk1)
Volumes exported by partitions or storage systems hosted on the above device:
Flash Storage                            (disk2s1)
iMac HD                                  (disk3s1)
Your computer must have exactly 1 solid-state and 1 rotational disk drive
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
What is your MacOS version?
完成的
10.14.2 on iMac 18,3
完成的
添加一条评论
1个答案
最有帮助的答案
Give this Apple T/N a try How to fix a split Fusion Drive
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
kevheath 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 3,035
