跳转到主内容
加入维修社区 - 创建账户
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
Why won't my iPhone turn on?
Hey everyone, I just bought an iphone on ebay, and it doesnt turn on. The internals are 100% fine, it just has no signs on life with a brand new screen I just put on it. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
I have iphone x , while playing pubg it turns off automatically , now it is not turning on and not showing tha apple logo after force reset..
完成的
Same exact problem tried fixing using itunes still the pc don't recognize my phone
完成的
添加一条评论
4个答案
最有帮助的答案
Can you get it to connect to a computer?
Hold down the power button. (i know) It may seem a bit rude to ask that. But i know some people that have forgot to hold down the power button before.
Try tilting the charger a bit while plugged in to make sure it has a good connective current.
If that doesn’t work, this is a great troubleshooting guide.
这个答案有帮助吗?
得分 1
19条评论:
I held it down, and tilted it, still nothing.
完成的
I also connected to computer and it didnt work
完成的
The phone is probably saying (if its there at all) "Do you want to trust this device?" So let me do some research and I will list some other ideas.
完成的
On an iPhone 8 or later: Press and quickly release the Volume Up button. Press and quickly release the Volume Down button. Then press and hold the Side button until you see the Apple logo.
Website: https://support.apple.com/en-us/HT201412
完成的
ive tried plugging it into a display too
完成的
显示更多的14条评论
添加一条评论
Check your LDI indicators to see if your device is liquid damaged. They are little white bars that turn red in contact with a liquid.
这个答案有帮助吗?
得分 0
2条评论:
there is no liquid damage
完成的
Have you checked if your battery is good with a multi-meter?
完成的
添加一条评论
请参阅图像内容:
这个答案有帮助吗?
得分 0
添加一条评论
never buy a used phone that dosent turn on. especially iphones, because most likely even if you get it to power on the old owners apple id (icloud account) will still be logged in. and if thats the case the phone is a paperweight to anyone but the original owner. i would just open an ebay return and be done with it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Philip Doherty 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 13
总计 5,743
