跳转到主内容
Kenmore is a popular appliance brand commonly sold by Sears, but Sears does not manufacture any of the appliances themselves. Instead, they source that out and have other manufacturers make their appliances for them. Kenmore refrigerators are made by a variety of different manufacturers including LG, Electrolux, GE, and Whirlpool.
125 个问题 查看全部
Same as many Fridge not cooling Freezer is , no Ice build up
Tired of living out of a ice chest. Wanting to take a chance and order a part. My Kenmore 795.72053 Same as many Fridge not cooling Freezer is but freezer not meeting the mark of what I have it set at. I have not had any Error codes. There is no ice build up on the coils. Need to try something. I have cleaned  condenser coils. Also The condenser motor just runs and never stops running Thank you for any help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
A defective evaporator fan motor could cause the compressor to run excessively. if the motor is unusually noisy when the refrigerator is running or the fan blade does not turn freely. ... condenser fan motor can cause the same problem by failing to draw air past the condenser coils check.
UPDATE
Refrigerator Evaporator Fan Motor
https://www.searspartsdirect.com/part-nu...
Kenmore 106.56536400 Damper Control/Air Diffuser - Genuine OEM
https://www.genuinereplacementparts.com/...
这个答案有帮助吗?
得分 2
1条评论:
Thank you for your time Mayer
Is the evaporator motor the same as the Damper motor?
完成的
添加一条评论
添加你的答案
Tracy Zoller 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 90
