跳转到主内容
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 个问题 查看全部
What is this Vertical bar of Inverted Colours on my Screen?
I was cleaning my Macbook Air at the weekend and think I might have damaged the screen. A vertical bar of inverted colours appeared on the left-hand side (the right was fine initially) but then both sides of the screen displayed as shown in the image.
After about an hour of doing nothing, the bar on the left-hand side returned to normal but the right-hand side bar has been there since.
I’ve tried:
  • Pressing around the screen (does nothing)
  • Cleaning it again (gently and with no cleaning fluid)
  • Connecting it to an external monitor (output is fine which suggests the GPU is fine)
Any ideas what has happened? It’s a 6-year-old machine but I’ve never had any issues with it until the weekend.
Does the screen need to be replaced?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I hope no water/cleaning detergent dripped into the frame as under there on the bottom side you got the full array of screen panel components and if that’s the case, screen might be fried. Try reseating the connector after unplugging the battery just not to let that untried.
这个答案有帮助吗?
得分 2
1条评论:
Afraid so...just strange that it broke on one side and then reversed later on.
完成的
添加一条评论
I suspect you used a spray cleaner on your screen and the liquid dripped under the bezel wetting the LVDS connector. Now you have a resistive short as the cleaner has dried but left a film of corrosion across the connection.
At this point you’ll need to try to clean the connections. To even get to the connector you’ll need to take the display fully off following this guide MacBook Air 13" Mid 2012 Display Assembly Replacement with the display off slide the clutch cover off to expose the bottom of the display. Locate the LVDS cable connector carefully remove the cable so you can clean the connector.
If you can’t clean it then you’ll need a new screen MacBook Air 13" (Mid 2012) Display Assembly
MacBook Air 13" (Mid 2012) Display Assembly图片
产品
$164.99
这个答案有帮助吗?
得分 2
1条评论:
OK, thanks for your help. What do you suggest attempting to clean it with?
完成的
添加一条评论
添加你的答案
John Peden 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 1,415
