跳转到主内容
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
LCD Backlight not working if battery over 80% charged
I have a rather unique problem i have cracked an replaced the lcd + digitizer the problem appears both with the cracked LCD and a new one so i am assuming i messed up something on the board itself
THE LCD BACKLIGHT IS NOT WORKING WHEN CHARGED OVER 80% go figure
Can anyone help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Weird. Never hurts to try a Reset. Hold together Home and Power buttons for about 15 seconds, let iPhone turn off itself and then it will turn back on.
完成的
添加一条评论
1个答案
已选择的解决方案
It may be a heat related issue - check for loose connections. Does the battery look swollen? It may be expanding a little when hot?
If not then you may need to replace the display
iPhone 3GS Display
[关联产品丢失或禁用: IF142-002]
Replace the LCD in an iPhone 3GS and fix a malfunctioning display. The display is only the internal LCD panel. The front glass digitizer touch screen and the metal backing plate are not included.图片
产品
iPhone 3GS Display
$19.99
Replacement 1219 mAh battery for iPhone 3GS. Compatible with all iPhone 3GS models. Does not require soldering.图片
产品
iPhone 3GS Battery
$14.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Hrvoje 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,636
