跳转到主内容
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
143 个问题 查看全部
which harddrive do I choose for my macook pro 2011
Hello,
Which harddrive do I choose for MacBook Pro 2011? It’s the only thing that needs to be repaired. I want the least expensive I can choose from while still having quality (so not the cheapest). Please send me a few options I have a choice from.
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Here’s a good run down on the better drives: TechRadar - Best hard drives 2019: the top HDD for desktops and laptops
I prefer the Seagate Barracuda HDD or Seagate FireCuda SSHD. But to be honest I’ve moved to SSD’s in my laptops as I tend to bang them around and SSD’s hold up better, but they are more expensive. Samsung 860 EVO is what I use.
In either case you really need to also replace the HD SATA cable as well. Often times your current cable is the older version which can’t support the higher data rate the newer drives can push, and in some the cable is worn or damaged. As you didn’t tell us which model (13” or 15”) heres your choices:
And Yes! These are for the 2012 models as the cable is better built in this series and fit and work in your system. In addition to replacing the cable you’ll want to place a strip of electricians tape on the uppercase where the cable crosses over to help protect the cable from the rough surface of the case. In addition you don’t want sharp creases in cable around the corner bends, you want smooth arcs as you can damage the fragile foil wires within the ribbon cable.
MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable图片
产品
$19.99
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable图片
产品
$34.99
这个答案有帮助吗?
得分 0
1条评论:
I do recommend you stick with MacOS Sierra on your system as High Sierra & Mojave introduced a new file system APFS which has issues with SATA based drives.
完成的
添加一条评论
添加你的答案
B M 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 43
