跳转到主内容
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 个问题 查看全部
Cracked display cover glass, can it be replaced?
Hello,
The front cover glass of the iMac 27” (Late 2013) has a crack. The LCD Screen is completely OK (no pixel-errors or lines)
I suppose the cover glass is complete glued to the LCD Frame. Is there a way to separate the cover glass from the LCD Frame?
If possible, I would like to replace this glossy glass with a Matte. I really hate all this glossy glass (iMac, MacBook)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The cover glass is not available as a part and taking the assembly apart is not easy! Trust me I tried! Best to just get a new screen or live with the crack if it’s not across the center third of the screen.
Here’s the IFIXIT guide you’ll need to follow iMac Intel 27" EMC 2639 显示器更换 Make sure you use the proper tools and techniques outlined in the guide, if you don’t you’ll likely damage the screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gerard Dirks 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 455
