跳转到主内容
Possible to semi-rebuild a Dell Inspiron laptop and make it faster?
I have an old Dell Inspiron 1720, still working, just isincredibly slow. I’ve backed up everything that I had on it, haven’t been actively using it for several years.
Is it possible to semi-rebuild the laptop with new parts that will make it run better/more efficiently/less loudly? (fan used to go constantly even after pulling it apart and cleaning it)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
You haven’t given any of your current specifications but the RAM can be upgraded to 4GB DDR2 PC2-6400 (2x2GB - a pair is better than one 4GB) and the SATA hard drive to an SSD. Just noticed that it has an option for a second hard drive so your old one could be used for extra storage space.
For example:
https://www.crucial.com/usa/en/compatibl...
but other sources are fine.
It has a dual core processor which is good.
It can also be upgraded to Windows 10 for free if it has a legal Windows 7 or higher.
Newer drivers will also help.
So yes can be ‘semi-rebuilt’ as you put it. DELL has manuals for it on their website.
I would not try to play any games on it but would be fine for work.
Please ask if you have any more questions.
Re: Fan
The fan going constantly could be a software issue such as a driver but again upgrading RAM to 4GB, a SSD SATA drive and finally upgrade to Windows 10 would probably do the trick.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ashleigh 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 15
总计 376
