跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
Device powers off when plugged in
Yes, plugged in. Laptop won’t charge, light on magsafe is off. As soon as I connect the magsafe into the macbook, the screen will turn off.
Have tried different chargers, reset PRAM, SMC, manually disconnecting and reconnecting battery, nothing.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It sounds like you have a short along the main power line. Try opening up the bottom and inspect the I/O board, I wouldn’t be surprised you’d see something burnt or charred. If you feel like doing it yourself you may try replacing the I/O board and connecting cable, but you also run the risk of throwing time and money, be aware of that. However this definitely seems a hardware problem.
MacBook Air 13" (Mid 2013-2017) I/O Board
MacBook Air 13" (Mid 2013-2017) I/O Board Cable
Replace an I/O Board Cable compatible with the Mid 2013 to 2017 13" MacBook Air laptop. Fix the connection between the I/O Board and the Logic Board.图片
产品
$14.99
Replace a used I/O board compatible with the Mid 2013 to 2017 MacBook Air 13" laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe 2 power, USB, and audio ports.图片
产品
$52.99
这个答案有帮助吗?
得分 3
3条评论:
Swapped the i/o board, issue persists.
完成的
I/O cable! That's what it was, thanks!
完成的
@gatovandalico Great, happy that worked ! It would be nice if you'd mark the answer as accepted, so that it may serve as a reference for future similar problems, thanks.
完成的
添加一条评论
添加你的答案
el gato 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 70
