跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
Replacing Apple SSD with and Aftermarket one?
Hi, I have tried to search for this but have found it very difficult to find anything that isnt about using an optibay to add an SSD.
If I have an Apple SSD in my MPB and later want to change it to an after market, higher capacity SSD, is this a straightforward plug out plug in and does it void warranty if I do it myself?
Thanks
P.S what brand does Apple use for their stock SSDs for the 2011 models? again have tried to search but come up with lots of different answers.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
I just did this (replace an Apple SSD with a third-party SSD). I'm not at all familiar/good with hardware of any kind, and I found it to be not that bad. The Apple 120G SSD drive I took out I believe was a Sony. I replaced it with an OWC 240G, which supposedly "wears" better over the long run and the model I picked has a 5-year warranty. By the way, I'm not connected with OWC in any way, but they seem to have similar goals as this site does, just coming from the "for profit" point of view.
The new disk does connect at the laptop's full SATA III speed (6G bits/sec), which is better than the Apple SSD, which always connected at the lower SATA II speed (3G bits/sec). I verified the connection speeds with the System Profiler utility, running it both before and after the change.
Watching their installation video convinced me that I could do it, which is saying at lot. The URL is:
http://eshop.macsales.com/installvideos/...
Also, I believe the Apple warranty states that you can change the memory and the disk and still be OK. The booklet that comes with the laptop even has a section on upgrading the machine by changing the memory and/or the disk.
Bryan
这个答案有帮助吗?
得分 1
添加一条评论
Straightforward, this guide would be your best bet.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cmc401 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 2,463
