跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
My phone has been on 1% for three hours now on the charger
my phone was at 19% and then suddenly jumped to 1% and shut down, I can't turn it on at all (even tried to hard reset and it didn't work) so i put it on the charger and now it's stuck at 1%. it's been charging for three hours.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Either the battery died or something went bad with charging circuit. Unless you have a multimeter to test battery voltage and connector on the iphone board you may try to replace the battery and hope for the best.
这个答案有帮助吗?
得分 3
1条评论:
One thing all mobile phone owners should have is a USB Ammeter. You can check your charger, cable for voltage and current draw. They cost about $15. My meter has saved 5-6 people from phone repair when phone was fine but cable/chargers were bad. Edit: iFixit has meter for sale: $9.99!
USB Mini Voltmeter
完成的
添加一条评论
That is the problem of SWI line, Bad Contact of the battery and battery connector cause that issues.
Battery have 3 pin to connection.
1 +VE
2 -VE
3- SWI- the center of the battery connector.
You can also check by the 3Utool the status like below on the image.
First image shows the Detail of the battery means SWI is connected stage.
Second image shows the BSI not connected or faulty or bad contact.
By this way you can find out the proper solution.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lilith Yandow 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 6
总计 668
