跳转到主内容
加入维修社区 - 创建账户
Sanyo(三洋)于 2007 年发布的 50 英寸等离子电视。
Why do my speakers make a static noise when my tv is on HDMI
I have a sinotech 32inch tv and when I plug my speakers into the aux audio output it makes a static noise, it only works if my tv is on the usb or pc channel but on tv and hdmi just a static noise , I have tried 3 different speakers .. all the same result
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
There are several causes that can produce a static noise:
1- Your HDMI cable is made of bad quality, it can produce a magnetic field that interfere with audio output wires, to eliminate this possibility try another cable.
2- The TV motherboard architecture isn’t very good or broken.
这个答案有帮助吗?
得分 0
添加一条评论
8% it is turning on but it don't want to work is not show nothing but it just talk when you collected to something it just talk but not showing something but you are achie
这个答案有帮助吗?
得分 0
1条评论:
Is it is not working but it's turned on if you connect if you connected to something you can hear the voice
由完成的 分享
添加一条评论
添加你的答案
Angelina 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 31
总计 4,099
