跳转到主内容
加入维修社区 - 创建账户
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
Rear camera only working in Facebook?
Okay so I dropped my phone pretty bad, the back of the phone has lost a lot of glass but that doesn’t bother me too much, what does bother me is the rear camera isn’t working anymore, it’s just black on the camera app, snapchat and everything else apart from Facebook where it works.I was going to replace the rear camera but then got thinking and if the camera still works in Facebook, does that mean it’s a connection or processor that has broken/disconnected and not the camera has broken. Any advice on what it could be?
thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
There is a post similar to this on the apple help forum. Someone said to set it up as a new iphone using itunes. However, I worry that doing that will most likely wipe all of your data.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for the reply man, yeah I read that yesterday, the only thing is it broke the second I dropped it which makes me think it’s physical issue not a software problem
完成的
I found a similar post only it's with the Iphone 6 Camera not working after drop
完成的
添加一条评论
Does it not work on both 1x and 2x? I suspect that you have broke one of the cameras and not the other, however they are housed in one unit.
这个答案有帮助吗?
得分 0
2条评论:
Yeah in the app it doesn’t let me use 1x or 2x however Facebook uses a zoomed in camera probably 2x so I think you might have hit the nail on the head there, should I replace the camera??
完成的
yes, unfortunately they are quiet expensive.
完成的
添加一条评论
添加你的答案
jimevans348 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 2,397
