跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Camera not working after drop
Hi there,
I have a customer that dropped his two week old iPhone 6. Screen was broken but housing is still mint because of a good case.
I had ordered a new screen assembly and a new rear camera. Repair went perfectly, it's not my first iPhone 6. But when I powered it up, the camera problem was still the same;
camera app opens up but shows only black image. It is however possible to turn to the front camera.
The flash light isn't working either, that was also the case with iPhone 5 that had faulty cameras.
Any advice? I might advise him to take his phone to the store for warranty. The repair was done without fingerprints and such so they won't notice.
Kind regards,
Renaat
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
6条评论
i also have this same issue. Any luck fixing it?
完成的
Me too I dropped it and it cracked the screen saver I took it off and the front facing camera doesn’t work now
完成的
My back phone fell out of my pocket, and fell face first and cracked on the up left corner by my camera and when I try to take a picture both front and back camera are black and my flash doesn’t work.
完成的
The same thing happened with my iPhone 7 and I went to apple got a screen repair and everything was good but I dropped it today and now the front camera works but the rear doesn’t and neither does the flash and I’ve restarted it a bunch of time but it stays the same
完成的
Help@Robert G
完成的
显示更多的1条评论
添加一条评论
6个答案
已选择的解决方案
It's probably the rear camera IC chip needing to be replaced if you already tried replacing the rear camera. I had it done for me once so I know it's possible.
这个答案有帮助吗?
得分 5
2条评论:
How much will it be to get it replaced?
完成的
Depends on where you take it to. Probably $60-$80.
完成的
添加一条评论
hope this guide will help you https://support.apple.com/en-us/HT203040
这个答案有帮助吗?
得分 2
2条评论:
I used the link above ‘support’ & switching phone on & off worked!
Thank you :)
完成的
After seeing a suggestion to turn phone in and off, instead I refreshed my phone by holding the on/off button and the home button at the same time(like a screenshot).
Hold them both down till the screen goes black. Wait about 8 seconds before turning it on.
The camera worked instantly and so did the flashlight!!
完成的
添加一条评论
You believe or not but for the first time when i dropped my phone the camera din't worked util few days after i accidentally dropped it again then i switched on. Unbelievably the camera started to work again
这个答案有帮助吗?
得分 1
1条评论:
How exactly did you drop it ?
完成的
添加一条评论
My brother's Iphone 6 + was dropped on the ground and the front of the screen cracked, and now his backfacing camera wont work at all.
the phone wont even switch to the back camera.
Anyone have any idea why?
这个答案有帮助吗?
得分 0
添加一条评论
Drop it again it worked for me
这个答案有帮助吗?
得分 0
2条评论:
You idiot what if it breaks. Dwn the screen breaks
完成的
Haha that's funny
完成的
添加一条评论
As if you saw bens answer he’s correct but it might still not work if it’s more damaged just to let you know not trying to be offended.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
RenaatS 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 21
过去 30 天: 66
总计 146,899
