跳转到主内容
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
84 个问题 查看全部
Replacing the lcd with a different one.
I have a TI-84 Plus CE-T With fancy broaken LCD rainbow colors on the screen. I took it apart and after inspecting the LCD, I couldn’t find any part number markings that gave me any results on searx, aliexpress or ebay. I figured that this screen is probably using a somewhat standard protocol and pinout. Therefore I was wondering if I might be able to replace it with a simularely specced lcd from aliexpress with the same amount of pins on the connector. I ended up finding this part
https://www.aliexpress.com/item/IPS-2-8-...
The connector looks right and has the right amound of pins allthough it is upside down and on the wrong side, I could probably just fold the flat flex connector though. Does anybody how likely it would be for something like this to work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
(Note: I had a lot of help from MateoConLechuga on this answer)
Hi, a screen replacement is likely to work, however your part seems to be incorrect. The display is a GiantPlus GPM1421C0 the latest display is a GPM1607A1 fortunately, it doesn’t matter which one you get since they are interchangeable. Unfortunately, we have no idea where you could buy one, we believe TI sources them directly. :(
If you want to be sure you’re getting the correct display, I would suggest buying a broken TI 84 Plus CE(-t) that still has a working display and salvage the display out of that. Make sure not to buy a TI 84 Plus CSE since the display is NOT compatible with the TI 84 Plus CE(-t).
Just out of curiosity, does RAM resetting or reinstalling the OS help fix your display? Does this answer on helping repair an LCD and running the display self test help ( Broken pixels came back on my ti 84 plus ce LCD, can this be fixed? )? Good luck with your repair!
这个答案有帮助吗?
得分 2
2条评论:
I am sadly talking about something which is definately not a software problem, It really looks exactly like what you would see on a broaken lcd, and i can even see the chemicals floating through the screen when lifting the lcd off of the backlight. I don't really feel like buying a broaken TI-84 because I already have a good calculator and I got this one from my sister and I tought it would be fun to try to fix it but anything more than $10 would a bit too much when I don't have any actual use for the calculator. It just seems like a fun experiment to get one fo these aliexpress displays and see if it would work and I was wondering if anybody else has tried something like this in the past so I wouldn't just be throwing away money.
完成的
@tt_392 Perhaps you can get a better answer if you post on a calculator forum such as Cemetech.net or TIPlanet.org . There are quite a few calculator enthusiasts out there who might be able to tell you what other displays might be compatible.
完成的
添加一条评论
添加你的答案
TT-392 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 67
总计 3,267
