跳转到主内容
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
LCD part number diferences
I would like to change the lcd in a 2nd generation ipad. The original part number on the back of the lcd is  lp097x02-sln1. I know there is a lp097x02- slq1 as well. I do not know the difference. Will they interchange? could someone please explain to me the difference between them. I believe they are both 2nd generation lcd screens.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I don’t know if this applies in particular to the codes you mention but very often different numbers correspond to the same panel with different mountings, it’s not unusual one lcd model is used by different tablet manufacturers. Unless you have a very good reason for venturing into lcd minor details I’d stick with the code you found on your original one.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Turbo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 121
