跳转到主内容
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
212 个问题 查看全部
Hardware Diagnostic Failure Code 4SNS/1/40000001:YH1R-0.000
What is this sensor? Temperature sensor right?
I’ve been using this iMac on and off a little bit and also reinstalled High Sierra 2-3 times and Mojave once without any issues or freezes.
Also ran a bunch of hardware diagnostics and that error popped up twice out of 10 or so. iStat Menus currently reports proper CPU temps, low to mid 30’s and ~60 under stress.
Several days ago it reported 100-130 though. I’m not complaining if the problem has disappeared … :)
To ensure there aren’t any significant problems caused by sensor failure what can I do that I haven’t already done? Or, is anything even necessary?
Thanks for the help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
So I went to the Apple Store and it looks like the error was that the Samsung SSD I upgraded the iMac to wasn’t reporting it’s temperature and voltage to the computer because of a minor incompatibility - the computer didn’t know how to read it from the drive. It still works fine though so nothing to worry about.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Sadly, Apple does not publish this series sensor errors, I wouldn’t discount it!
I would bring the system into an Apple Store to get them to tell you what the error is and then decide if its something you need to worry about.
Some thinks I would look at is making sure your outlet is properly wired and is properly grounded back to the breaker panel and onward to the ground point (rod or water line pipe) and ti electrically active (not corroded up)
I would make sure you have a good surge suppressor or better yet a UPS for your system as well as your peripheral devices as a surge can also come in via the USB or Ethernet cable.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Josh Orenberg 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 138
