跳转到主内容
加入维修社区 - 创建账户
Some things just don't quite fit in.
USB drive won't fit into previously used USB ports
my USB drive will not fit into any of the ports that's it usually in... I just had it in my laptop this morning, and when I got to work it no longer goes into any ports on my work computer. I've already used these computers with my USB many times so I'm guessing maybe the USB has been damaged?? If so, is there ANY way to get my files off of it??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
You’ll have to closely inspect both the USB port on your computer and on the USB Drive as one (or both) of them is physically damaged. If the USB drive is damaged, then someone who does micro-soldering repair should be able to repair the port.
这个答案有帮助吗?
得分 3
添加一条评论
Check the USB drive’s port for obstructions. Lint, paper pieces, small dirt or other things may cause it to not insert completely.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tami B 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 10,751
