跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
Can I install 3 SSDs by replacing the optical drive?
Hi,
I already have 2 SSDs in my iMac (iMac Intel 27" EMC 2429, 2011), one is replacing the original HD (with the thermal probe) and the second one is behind the optical drive. Can I remove the optical drive and install a 3rd SSD? Do I need any special parts if this is possible (like the thermal probe) ?
Thank you!
Tom
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
While its theoretically possible I don’t think you’ll gain that much as the Optical drive port is only SATA II (3.0 Gb/s). I would put in a large 2.5” SATA II HDD instead or just leave the optical drive.
Basically, you’ll use the iMac & Mac mini Dual Drive Enclosure following the optical drive swap out iMac Intel 27" EMC 2429 Optical Drive Replacement. Don’t forget you’ll need a drive that runs at SATA II (3.0 Gb/s)
How about just getting a bigger SSD, swapping out your oldest drive with it. Bigger SSD’s are faster!
iMac & Mac mini Dual Drive Enclosure图片
产品
$19.99
这个答案有帮助吗?
得分 1
1条评论:
Thank you Dan for your very fast reply!
I thought the optical bus was also SATA III, but if it’s SATA II, it makes no sense to connect an SSD.
All the best,
Tom
完成的
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 48
