跳转到主内容
型号A1288,闪存容量:8、16及32GB
451 个问题 查看全部
Why is my iPod stuck at a white screen?
I recently purcahsed a faulty iPod Touch on eBay and have been trying to fix it and have had a modicum of success. At first it wouldn't respond to any kind of power and so I ordered a replacement battery and it now is recognised in iTunes as an iPod Touch and can be synced to. The only problem was that the Display was just white. At first I thought this was because I'd damaged the display when I'd tried to fix another iPod so I ordered a new one but it still exhibits the same problem, does this mean the Logic Board has gone or is there another fix that I should try?
In addition when I connected it to iTunes I did a format to restore but the Display is still white.
Thank you very much
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Zagreus, have you tried to to hold down the power button and middle button ( the only one) for 10 secconds until the apple appears?
完成的
Yes, now I've replaced the digitiser I tried it and it's still white, it's looking more and more like a logic board problem
完成的
添加一条评论
3个答案
已选择的解决方案
You are correct. That definitely sounds like a bad/damaged logic board. I recommend replacing it and hopefully it will fix the problem.
这个答案有帮助吗?
得分 1
添加一条评论
And here's the guide!
iPod Touch 2nd Generation Logic Board Replacement
这个答案有帮助吗?
得分 1
添加一条评论
my ipod touch is stuck on a white screen. I got it to work but when i updated my software, it did it again and i have not been able to fix it since then. PLEASE HELP!!!!!!!!!!!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zagreus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,836
