跳转到主内容
加入维修社区 - 创建账户
Lighting jack is not working
My iPad Air 2 is not charging. I’ve tried restarting the device, cleaning out the lighting port, changing cords, chargers, and wall outlets to no avail. I was looking for other ideas as tot he cause, or for a replacement part to replace the defective part.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Thank you all for the info. Much appreciated!
完成的
添加一条评论
2个答案
Unfortunately, your port may be defective. It is soldered to the Logic Board and would require micro-soldering to be replaced. If you want to repair it, it may be cheaper to take it to Apple, as micro-soldering can be very expensive.
这个答案有帮助吗?
得分 0
添加一条评论
You can buy a replacement charging dock voor the ipad air 2 it isnt that hard to repair no soldering needed , buy one with flex cable.
这个答案有帮助吗?
得分 0
2条评论:
The charging port flex assembly is connected via soldering to the logic board. So it will require soldering to replace that charging port.
Good video on how it's done here: https://www.youtube.com/watch?v=IdyIQYrO...
完成的
Alec and Ben , sorry you are right. For the normal ipad 2 it is easier and with a flex cable.
完成的
添加一条评论
添加你的答案
Ryan Lantz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 29
总计 428
