跳转到主内容
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
61 个问题 查看全部
Can I use the glass and battery from a mini 2 on a mini 1
I recently found a iPad mini 1 in a recycling center. The battery is a bit bloated and the glass is cracked. Can I use the glass and battery from a mini 2 to fix the mini 1? I dont need the LCD just the glass. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi Ethan, yes you can, the IC chip is the same one from the iPad Mini 1. Therefore, you can use the glass. However, the battery is not compatible.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ethan Leroux 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 20
总计 337
