跳转到主内容
A large smartphone by LG, released in fall 2014. The LG G3 (D855) boasts a Quad HD IPS display and a 13-megapixel camera.
180 个问题 查看全部
Why is my battery health percentage so high?
Hi, I have downloaded accubattery to check battery health of my lg g3. I haven't used this phone in a while because the battery would drain in less than 3 hours and would take forever to recharge.. I didn't want to spend the $ to get it checked so have left it in a drawer and have it out agaun because i still love the g3! So on the accubattery app, my battery health is displaying 938% saying my estimated capacity is 28,153mah when the design capacity is 3,000mah . What does this mean and why would it do this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
sounds like a bad battery, i guess just change your battery and you may be fine.
这个答案有帮助吗?
得分 0
添加一条评论
I’d agree that it’s probably be a bad battery. Whenever you start using a phone again after a long period, let it charge overnight without touching it. the battery indicator will usually be messed up and it takes a while for it to reset. For continued usage of your phone, let the battery cycle. This means charge it fully, then use it until it’s almost completely empty (don’t let it get completely empty, this may harm your phone, so 10-15% should be good), and then charge it fully again without using it. This should improve battery life a bit, but honestly it’s actually really easy to replace the battery. You can use this guide (it’s dead simple) after buying a replacement battery, and then your phone should be working fine again!
Carpe Diem,
Minas
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jessica 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 161
