跳转到主内容
The Epson Artisan 1430 is a color inkjet photo printer.
32 个问题 查看全部
Why is my paper not feeding?
The printer will pull in the paper for about an inch and then stop & continue printing…on no paper. When it pulls in a little it wrinkles on the right side.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Here’s a video on how to clean the paper feed rollers on your printer:
https://www.youtube.com/watch?v=eJBmi1_J...
这个答案有帮助吗?
得分 3
添加一条评论
try running maintenance onto your printer… just open microsoft word, then click on file, next, click on print, then on the left side of it click printer properties, another dialog box appears, then go to the maintenance tab and you will see bottom plate cleaning and rolling plate cleaning, let’s see if it will work
这个答案有帮助吗?
得分 0
添加一条评论
Make Shure that the paper is being picked up by the guise wheels. If not open it up and check for foreign objects or paper Jams stuck in the way of the paper. Something as small as 4 grains of rice, positioned in the right way can stop everything.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Carrie Garms 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 11
过去 30 天: 43
总计 4,453
