跳转到主内容
The Nintendo DS is Nintendo's seventh generation handheld game console and is the first of its kind across all systems with dual-screen technology and use, apart from clamshell Game & Watch systems.
DS No Longer Working After Disassembly
I decided to open up my original DS so I could clean some dust. After cleaning the dust from inside my DS, I tried to power it on but the green light momentarily powered on for a split second along with the bottom display. I then took it apart again to make sure I plugged in every ribbon cable but when I put it all together and plugged it in, there was absolutely nothing except the speaker pop when you press the power button. I plugged my DS into the wall and tried powering it on but still experienced the same issue but with the orange charging light on. Can anyone help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi
i had the same symptoms with a incorrectly inserted wifi module. Have a try to unplug it and replug it
这个答案有帮助吗?
得分 0
1条评论:
You can’t remove the WiFi module on the original DS so I just unplugged and plugged the antenna to the WiFi module and it didn’t help.
完成的
添加一条评论
添加你的答案
TheLoneGamer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 155
