跳转到主内容
Repair guides and support information for televisions manufactured by RCA.
181 个问题 查看全部
Won't turn on anyway to reset it?
My RCA 32 inch. Won't turn on anyway to reset it? I tried to reset it the remote but there was no clear button on the remote so I could not use the remote to reset it. There is a red light on but everytime I try to press the power button it doesn't turn off and I don't know what to do.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
tv cut on an off red light flashing I can unplug it an it flashes one time than red light flashing
完成的
添加一条评论
1个答案
最有帮助的答案
Katelin Hieber  it is possible that this is a power board issue or a main board issue. We would need you to give us the complete model number for your TV and have you remove the back from it. Take a look at the boards (after unplugging the set) and check for obvious damage like domed, leaky capacitors etc. After that you will need a multimeter to check the fuses, connectors etc. You can always post some pictures of your boards with your question so that we can see what you see. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
1条评论:
Me too. I'm sending pics of back. Fingers crossed hoping you can help
完成的
添加一条评论
添加你的答案
Katelin Hieber 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 8,856
