跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
Black screen on boot after replacing the top lid
I got this MacBook Pro Early 2015 model, The screen is messed up, it still displays picture just the right side is cracked. I ordered a replacement screen and installed it.
On boot its black no display. If I close the lid the Apple logo lights up, then I re-open the lid and the display is fine. If I restart with or without the power adapter it boots to a black screen. I tried clearing the PRAM and EMC. Same issue.
So i reinstalled the original screen and it displays the picture right away just like it should.
What am I missing?
Running Mojave
Update
I did that as instructed same behavior Here are 2 vids i just upload to youtube. I put the original screen back on. Took a video of it then Installed the replacement and took a video of it.
Oringal Screen: https://www.youtube.com/watch?v=zMoNKmnT...
Replacement: https://www.youtube.com/watch?v=a-zvgMXE...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
Where did you get the display and the P/N you used? Also did you replace the full assembly?
完成的
Well, the part number is the correct one for your system MacBook Pro 13" (Early 2015) Display. But I think you got this one MacBook Pro 13" (Late 2013-Mid 2014) Display. Which explains why your display is not working correctly.
完成的
添加一条评论
1个答案
最有帮助的答案
Double check that these:
are connected properly. You can find the order in step 8 of this guide. Also double check the the LCD cable is connected properly to the screen. Sometimes if the connection isn’t solid this can happen. After all that power cycle the MacBook
这个答案有帮助吗?
得分 2
1条评论:
Can you get a replacement?
完成的
添加一条评论
添加你的答案
mikebarkas 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 253
