跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Screen replacement not work?
I recently dropped my iPhone 3gs and shattered my screen. After pretty extensive research, I finally found the right replacement digitizer/glass kit with tools. I followed very precise instructions, and almost had everything ready. When it came time to do the last steps, re-connect the ribbons 1, 2, and 3, I had trouble getting the #2 to connect. It will not go in for anything! I literally tried to get this one ribbon to connect for an hour. Well, in the process, I was taking off ribbon #3 to see if I could do 2 first, and the little clasp that holds #3 in came off. Is this a huge deal? I have heard of other people running in to the same problem with clasp #2, and they taped a piece of paper over the top of it and it did the trick. What can I do about the broken clasp though? SOMEONE PLEASE HELP!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
never mind the clasp, it'll work fine without it...mine does. as for connector 2... check you have the right part/s and that you haven't been sent parts for a 3G. if it won't fit don't force it you'll only damage pins. get out a dividers or ruler or something else to measure, then check the 2 parts dimensions.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Sean Sealock 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 1,110
