跳转到主内容
Surface Laptop是微软Surface产品线中的第一个全笔记本,在2017年6月发布。
105 个问题 查看全部
Bottom of screen popped out. Something inside must have repositioned.
My Surface Pro 4 is working fine. There is about a 1/4” gap at the bottom of the screen as it has become separated from the unit. There appears to be a bulge inside somewhere keeping me from forcing the screen back to the bottom so the glue can set. I can’t seen inside. I have ordered the iOpener / Toolkit. What will I find inside?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Can you post a picture? It’s easier to tell.
The screen may pop out due to bent case, internal stress or swollen battery.
这个答案有帮助吗?
得分 2
添加一条评论
toughest part of this laptop is you have to tear down the keyboard using a knife as the screws are found below keyboard of the laptop as stated in ifixit 微软 Surface Laptop拆解
这个答案有帮助吗?
得分 1
2条评论:
There is no integrated keyboard with the Surface Pro 4.
完成的
Check the guide for tearing down for surface pro 4 system 微软 Surface Pro 4 拆解
完成的
添加一条评论
Same issue with me and it’s the swollen battery. Using the generated gap it’s much easier to separate the screen and then either to replace the battery or puncture the film of the swollen battery so that it recovers the original shape. If done within one day just place the screen over the original adhesive tape and voila.
Of course not recommended to puncture the battery but was OK for me for emergency use (take care not to overheat the battery during charging and better than breaking the screen) and then replace when new battery was available.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ray Franklin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 1,220
