De error but can't find where to put magnet on my LG 8kg 2010
Direct drive 8kg wt800 displaying de error code but don't know where to put new magnet
This video will show you the placement of the magnet:
这个答案有帮助吗?
A simple reset could clear the error. Power down the washer, unplug it and press the start button for at least 5 seconds. Plug it back in, power it up, and try to operate the washer.
If the washer still doesn't work, there are a few things that could be wrong. The top loader washers have a magnet in the door latch, and replacing the door latch will fix it if that's what is wrong. The door could also be bent or have bent hinges, causing an alignment issue and related damage. Sometimes the whole door needs replacing. Also, the door lock could be damaged. Front load washers suffer lock and latch damage much more than top loaders.
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 24
总计 1,625
