跳转到主内容
low-cost notebook with at least basic gaming power, includes the models G50-30, G50-45, G50-70, G50-80.
38 个问题 查看全部
My laptop is not turning on. It just showing repairing hard disk
My laptop is not working. When i turn on it just shows repairing and goes to login page and just stuck there. Even if i type the password it ask again to type password. My laptop is idapad z510.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi!
Did you drop your laptop recently?
完成的
No i havent dropped it. But there is a problem if the laptop is charging if i move the laptop it just turns off with a sound
完成的
添加一条评论
2个答案
已选择的解决方案
Hi,
You could try removing the HDD from the laptop and inserting it in another computer as a storage drive to try and get your data from the HDD before the drive completely fails.
There is a lot of information online how to do this. Here’s just one example.
To remove the HDD from your laptop, here’s a link to the service manual for your laptop. Scroll to p.46 to view the necessary pre-requisite steps and then the procedure to remove the HDD.
这个答案有帮助吗?
得分 2
1条评论:
I will definitely try this.
完成的
添加一条评论
Hi there, it seems to me as there is corruption in the hard drive, have you dropped it recently? or has the hard drive been impacted with some sort of force?
In this case you may need to replace the hard drive.
这个答案有帮助吗?
得分 1
4条评论:
what about the data and os
完成的
As jayeff suggested, try using the hard drive in your laptop in another laptop, if the other laptop boots fine with the hard drive from your laptop, it indicates there is an issue with the laptop itself.
完成的
Hi @jtblck ,
The host computer will boot OK as the "faulty" 2nd HDD is not part of the boot process. It is just additional hardware
You can't substitute the HDD in a host computer with the "faulty" HDD as the OS on the "faulty" HDD is configured for the motherboard hardware that it was originally connected to and it won't boot as there are too many differences unless it was an identical computer. (if this is what you mean)
You can however connect the "faulty" HDD as a 2nd HDD in another computer and then boot using the existing installed HDD and check if the 2nd HDD is detected, mounted and readable in the computer.
完成的
Huh, I've used other hard drive in other laptops like I mentioned before, and it seems to work well every time for me. But thanks, you learn something new every time. :)
完成的
添加一条评论
添加你的答案
Revanth Krishna 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 95
