跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
X in circle when attempting to install Mac OS X Snow Leopard
Hello!
Thank you for reading. I have a 2009 A1181, 150 GB Toshiba HDD that is working, I previously installed Windows on it.
I have attempted to install 10.8 through Hackintosh, it got about halfway when it told me that Installation could not finish, with an error code. The disc itself though still works.
I made a 10.6.3 USB with Apple media on it, and it goes through loading for 5 minutes or so, then gives me the X in the circle.
The HDD is working, the 2030 MB of RAM came from a working environment and is enough to install 10.6.3, I’m struggling to figure the problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Why did you try to Hackintosh it? It's already a Mac.
完成的
@guardian10 - Good point!
完成的
添加一条评论
1个答案
最有帮助的答案
Hi
You are probably best to partition your drive at this point so that windows is a separate part of your disk, then I would try and install macOS through internet recovery on the other part of the disk(not the windows partition)
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Nicholas Leonard 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 53
