跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
423 个问题 查看全部
My MacBook air won’t turn on! Charging fine?
Today I went to use my mac book air and it didn’t turn on. I thought it might be dead and I connected it to the charger. The charger orange light turned on fine but the laptop didn’t respond at all. No sounds no nothing. I tired the basic tricks and the orange light turned green for a few seconds and that’s it. The screen hasn’t lit up once. I 100% haven’t spilled anything on my laptop! So confused. The last time I used I connected a hard drive for the first time is that the problem? Is there any hope?
Ps I’m about 500 km from any Apple store.
Update (12/21/2018)
I bought it late 2016. I will try charging it and see what happens and see if that works. I’ve tried pressing the botton for 10 seconds and then turning it on then trying once more with charger it’s still none responsive.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
What is your purchase date?
完成的
添加一条评论
2个答案
最有帮助的答案
Trying for a spontaneous reboot. To do this unplug the battery and MagSafe. Press and hold the power button for ten-seconds. Hook up the battery and then Mag-Safe. You should get a spontaneous reboot.
Stay with us on this as even though you may be far from an Apple Store you are eligible for a flat rate repair. Depending when you bought it you may also be eligible for warranty service and you do have a FedEx service where you live? That’s what Apple uses when you are not close to a store or ASP.
这个答案有帮助吗?
得分 2
添加一条评论
The Amber MagSafe connector implies the battery needs to be charged. It needs to get to Green for a fully charged battery (give it a good 20 hrs).
If the MagSafe never gets to Green or has a dim green MagSafe connector thats a sign of a problem within your systems charging logic. Your system is too new to need a new battery.
Did you have a liquid spill or sit the system down on a wet surface?
Do you have AppleCare+? If you do, you should get it to an Apple Store or authorized service center.
While it maybe distant this could be quite costly to fix.
这个答案有帮助吗?
得分 1
3条评论:
Thank you I will give that a try
完成的
It’s now green still nothing unfortunately
完成的
Check your warranty status and if you have AppleCare+ give Apple a call for a shipping box.
If not covered time to make a visit ;-{ As I've found that works better to push for a warranty exception. But, the system can't have any liquid or physical damage.
完成的
添加一条评论
添加你的答案
ria 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 236
