跳转到主内容
Apple的 MacBook Pro 的產品線是專為可望極致效能專業使用者所打造。MacBook Pro 产品线包括了MacBook Pro 13" (一體成型機身款), MacBook Pro 15", MacBook Pro 15"(一體成型機款), MacBook Pro 17" 和 MacBook Pro 17" (一體成型機款)。
20001 个问题 查看全部
Screen is black, but has boot sounds
My MBP 15'', A1206 model, just got a black screen after it fell asleep, then it will never wake up. I pressed the power button and closed it. Then I tried to restart. The interesting thing is I can hear the boot sound, brightness adjustment sound etc. I think the system is on. But Screen is complete black, I can't see anything.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
Can you connect to an external display and check if that works? Also, shine a flashlight on the display and see if you can see anything.
完成的
yes ext display will tell us a lot - good thinking rab777hp. Why didn't I think of that? :-(
完成的
Rab you are on target for the place to start. Richdave there is no inverter on a MBP of this ERA. This has a LED backlight not a CCFL. They are 2 different animals that provide the same service.
完成的
There is no Mac of any kind with the designation of A1206. Please give us the last three letters of your serial number so we can identify your machine. Usually found in the battery compartment. Thanks
完成的
Thanks for all your response, I followed your suggestions, here is what I got:
1. Model number is: A1226 and the last 3 letters of my Serial number is YAM.
2. I did connect the external display, then I pressed start button, again I heard the boot sound, but no display. I can hear the sound adjustment beeps, brightness adjustment beeps and the num lock F6 green light. But I still cannot see anything either the main display or external display. However I'm not quite sure if I do right to make external display work.
3. I used a torch light, but I cannot see anything.
4. Another thing I noticed is after I boot the Mac for a while, even though I cannot see anything, I can hear a very long siren when I tried to shut down but long-press the power button. I don't know if this will help.
完成的
添加一条评论
2个答案
已选择的解决方案
Apple MacBook Pro "Core 2 Duo" 2.4 15" (SR) Specs
Identifiers: Mid/Late 2007, 2.4/2.2GHz* - MA896LL - MacBookPro3,1 - A1226 - 2136
My best guess on this is the Nvidia GPU processor issue. Most of the time this involves scrambled colors on the screen but also no screen. Contact Apple, they will most likely replace your logic board for free, they also pay for all shipping, it takes about four days total. Here's the Apple site on it: http://support.apple.com/kb/TS2377
Also see www.nvidiasettlement.com
这个答案有帮助吗?
得分 5
1条评论:
+ Great Answer
完成的
添加一条评论
Make sure everything is detached... Like USB ports and the like. Same thing happened to me and weirdly enough I had to pull out my headphones from the headphone jack and the screen came back!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Arnold 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 22,629
