跳转到主内容
Nintendo DSi 是 Nintendo DS 产品线的第三款迭代机型,于2008年底在日本市场发布。
Game will not load, gives an error
Games will not load on my son's DSI. Gives you the message that you need to hold the power button down and then refer to the owners manual. I do not know where the manual is. He has tried the game in his DS Lite and it worked, this is not a downloaded game it is a game we bought that has worked before now.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Thank you for the advice, we will try these!
完成的
I have pokemon platinum game for dsi and when I put it in and play it, it says error.
完成的
添加一条评论
3个答案
已选择的解决方案
try cleaning the gold contacts of the game and the DSi with a cotton tip dampened with ethanol, methanol or similar and then allow to dry.
这个答案有帮助吗?
得分 1
添加一条评论
Hey, the Wifi Board in your Dsi has gone bad or has disconnected from the motherboard.
Very Common error in the Dsi and Dsi XL. When the machine takes a fall the wifi board will come loose.
Remove the back cover and you will see a small board connected to the motherboard. Just make it is connected to the board. If it is, then the board may have gone bad.
这个答案有帮助吗?
得分 0
添加一条评论
How can i trouble shoot without the manuel
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Wendy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 7,262
