跳转到主内容
Xbox One 手柄在2016年随着 Xbox One S 的推出而问世,并增加了对 Windows 10/11 的蓝牙支持。 该手柄修复了 Model 1537/1697 手柄上的许多设计缺陷,更加可靠。该手柄已被改进版 Model 1914 手柄所取代。
Are Xbox One and Xbox One S controller faceplates interchangable
Is it possible to put an Xbox One controller faceplate on an Xbox One S controller (given that I have a complete original controller)
I want to have a Bluetooth model with a look of the Limited Edition Halo 5 controller…
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Depends on how much you care about the warranty and if both controllers use the same faceplate and cosmetic parts. If it will work and you care about keeping the warranty, use a skin. If you don’t care (or it’s the 90 day warranty that isn’t worth preserving if you can do the work yourself), then it can be done.
You will need to damage the identifying label (which will reduce the resale of the controller) and make it harder to sell later on to normal buyers (technically capable buyers probably won’t care) so you need to decide if the resale loss and voided warranty are worth having that faceplate.
这个答案有帮助吗?
得分 2
添加一条评论
!Yes it would work and you only need to unbolt some screws and change the face plate Follow the guide!
Xbox One 无线手柄(产品型号1708)盖板更换
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vincent 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 22
总计 1,548
