跳转到主内容
MacOS won't install on new Internal SSD
Hello!
I have a Macbook Air 11” early 2014. I don’t have the original SSD. I bought new one:
Toshiba 128 GB Model #: 656-0021B
The Mac will start up fine on a USB Bootable Flash Drive loaded with Sierra. I’ve tried it with newer OS, but they gave me more problems. Sierra has been the best so far. It lets me do the following steps:
Power system on while pressing Command R (USB Bootable Flash Drive with Sierra plugged in)
  • Open Disk Utility
  • Format Internal SSD to Mac Extended
  • Reinstall New OS
  • Select Internal SSD
Everything starts like normal then right when it finishes it goes to the light grey screen. If the USB is still plugged in it boots, but is still working off the USB. If the USB isn’t there it just does the folder Icon with the question mark.
So my main problem is getting the OS onto the internal hard drive. I’m wondering if I could get an enclosure or a SATA cable to instal the OS externally on a working computer. The problem is I can’t find an enclosure or cable compatible with the SSD I got.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
hi there, i just saw your post. I have had this exact issue with my client MacBook Air 2014. This Toshiba SSD is PCie and it is only compatible with 2015 models. 2014 models can not boot from it.
这个答案有帮助吗?
得分 3
2条评论:
Good Point!
It slipped my mind!
完成的
Hopefully IFixIt will replace it since they sold me one they said was compatible...
完成的
添加一条评论
最有帮助的答案
That's the correct stick. I do not see any mis-steps that you made. What was your source for it? Check to see if this enclosure will for for you, probably cheaper on eBay:
https://eshop.macsales.com/shop/external...
这个答案有帮助吗?
得分 3
4条评论:
FYI @mayer [关联产品丢失或禁用: IF107-148]
完成的
@danj Thanks, I was unaware that iFixit was selling them.
完成的
for that enclosure it says
"The OWC Envoy enclosure has been specifically designed for use only with the factory SSD found installed in the Mac models listed in compatibility. Do not attempt to install or use an OWC Aura SSD as external storage in an Envoy enclosure. This may damage the Aura drive, the Envoy enclosure, or both."
Is the SSD I have compatable? I bought the SSD from IFixit.
完成的
which SSD did you buy? Where did you put it?
完成的
添加一条评论
@kfy - IFIXIT also sold recovered Apple SSD’s besides selling the OWC SSD’s. If you look at yours you have an Apple unit so your good!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kyle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,058
