跳转到主内容
加入维修社区 - 创建账户
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
Engine will not crank.
All that I get is a click from the relay box under the hood. New battery and relay. Jump the starter and it turns. All lights come on then when you turn to start it everything on the dash turns off
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Trevor check your grounds both at the battery and on the frame . By the relay are you referring to the relay in the fuse panel or the starter solenoid . When you boost the car to start it are you connected to the battery for your ground or are you on the frame . Just as a test connect the booster cable to the ground(-) post of the battery and the other end of the cable to a solid ground point on the engine block ( don’t worry about the other side of the booster cable were just trying to make a new ground for the battery in this test). If it starts with just the new battery and no boost its probably a bad ground
这个答案有帮助吗?
得分 4
2条评论:
@jimfixer Good to hear from you ;-) You've been missed.
完成的
@mayer Ive started a new business and its been really busy. Finally getting things under control and hopefully getting back to normal
完成的
添加一条评论
添加你的答案
Trevor Winkleman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 262
