跳转到主内容
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
293 个问题 查看全部
CPU Upgrade from i5 3.4 GHz to i9-9900k?
Hello Guys.
I need some help, I bought 27” iMac 2017. Which has Intel 3.4 GHz i5.
But my question is, is it possible to upgrade to i9-9900k or i7-9700k?
I would like to know if I can and I don’t want to damage my system.
I appreciate your comments, thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Simple Answer not possible!
The i9 CPU’s use a different socket (high heat) and the systems EFI (BIOS) doesn’t offer the needed firmware support.
这个答案有帮助吗?
得分 2
3条评论:
Could you tell me which CPU could be work for that iMac? Thank you for your answer.
完成的
The top CPU in this series is the 4.2 GHz i7-7700K
iMac "Core i7" 4.2 27-Inch (5K, Mid-2017)
完成的
i7 7700k and i9 9900k share the same LGA 1151 socket. Probably it wouldn't work due to EFI restrictions or something.
完成的
添加一条评论
If you are in the SF Bay Area and have the CPU, I can rebuild the firmware. This is not rocket science. Man made machines should have ways to make them work. Never say no without giving a try.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
lopezclever 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 9
总计 1,658
