跳转到主内容
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
What is the speed of the MacBook Pro (Non-Retina) SSD Upgrade?
What is the speed of the ssd in the MacBook Pro (Non-Retina) SSD Upgrade Bundle?
thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
The drive included in the bundle is a Crucial MX300. Here’s a link to the suppliers website, I believe it has the info you need,
https://www.crucial.com/usa/en/storage-s...
Update (12/15/2018)
You may want to consider upgrading your laptop’s hard drive/IR sensor cable to a newer one from 2012 (it's compatible with your laptop, no worries about that ) that can support solid state drive speeds.
MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement
MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable
Replace a damaged cable connecting the hard drive to the logic board in your laptop.图片
产品
$19.99
这个答案有帮助吗?
得分 3
2条评论:
Thanks for the reply.
What are the benefits of changing the SATA cable? Thanks
完成的
The firs gen of cables didn't handle SATA III data rates well. Apple upgraded the cable. You also need to apply a piece of electricians tape on the uppercase when the cable rests against as the rough aluminum wears the cable and the second reason you want to replace it.
完成的
添加一条评论
To add to Dan’s comment. I had to post this as an answer to upload the photo.
Polyimide Tape
Electrical Tape in 6 Assorted Colors
Scotch Extreme Mounting Tape, 4 Foot
https://www.walmart.com/ip/Scotch-Extrem...
6 rolls in assorted colors.图片
产品
$9.99
108 foot rolls of Polyimide tape. Perfect match with OEM Apple Part# 922-1731 tape. Half-inch (.5") width.图片
产品
Polyimide Tape
$9.99
这个答案有帮助吗?
得分 3
1条评论:
Specifically what are the materials used?
完成的
添加一条评论
添加你的答案
SuperChan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 136
