跳转到主内容
加入维修社区 - 创建账户
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Cracked Case?
Near the thumb-scoop there appears to be a small crack running parallel to the case (follows the curve of the scoop) and is about the length of the trackpad button. It is only small but is there something I can do without replacing the entire case?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
You have to show it to your local Apple Service Provider. I some cases Apple will repair the MacBook.
- shurai
这个答案有帮助吗?
得分 2
1条评论:
It's not under warranty though
完成的
添加一条评论
I see, so the top case actually has a crack in it. For a complete fix you will need to replace this. You can use this guide to carry it out.
这个答案有帮助吗?
得分 2
2条评论:
I'd rather not pay $169 USD and just keep it as it is. It doesn't bother me so i will just leave it
完成的
I agree, maybe you could try shurai's suggestion?
完成的
添加一条评论
If the crack is on the keyboard then they'll repair it at no cost. They said it is recognized as a design flaw. However if the crack is anywhere else then you'll have to pay for it
这个答案有帮助吗?
得分 0
添加一条评论
I have the same problem with my black macbook, I use black electrical tape to cover it, it's the perfect color, if you have a white macbook you could use white electrical tape.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
AussieMac 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 33
总计 1,760
