跳转到主内容
2, 2.26, 2.53, or 2.66 GHz Core 2 Duo processor
106 个问题 查看全部
Is it still worth the trouble (and investment!)?
Hi everyone!
After a lot of research i have decided I can do it! Maybe…. Just maybe i can fix tech. So i found what looks like a really good deal. Some guy will sell me his Late 2009 mac mini for €85. If i upgrade it fully…. Is it still worth it?? Can i do basic work stuff on this machine??
Please give me some opinions I feel a bit lost…
THANKS in advance :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It’ll work for basic tasks, but I wouldn’t put a lot of money into it. Get a good SSD and max out the memory. Anything beyond that is probably going to cost more than the machine is worth unless it's a good enough upgrade to justify the cost. These machines are old and just aren't worth a lot.
If you are okay with the limits of an SSHD, then that will be cheaper than an SSD but it will still be subpar in comparison. I'm not a fan of them and have honestly had more issues than I do with a real SSD (one of them was suspect, and the 2nd had issues with the speed at 10k hours which means the NAND flash failed and you can't just disable it to bypass that). Because of my poor experience with them, I'm reluctant to try again. That said, they have a place for some users who can't afford an SSD and need a bridge that offers some improvement -- but I wouldn't trust it to last 10 years like a proper SSD.
这个答案有帮助吗?
得分 3
3条评论:
Thanx Nick!
Can you maybe elaborate on how basic these tasks would be? With an SSD and upgraded memory?
I was thinking… Media center stuff, photo presentations, internet navigation, youtube videos, maybe some productivity tools…?
Is this machine just too old?
Knowing I’m on a tight budget here, what would you recommend?
Thank u so much :)
完成的
Basic tasks essentially means things like web browsing and social media. It would work for light media center use as well. $107 USD is high; knock that price down somewhat if you can, especially for a 9 year old Mac.
SSHD's are cheaper then SSD's, but they leave something to be desired in my experience BUT I also have a quadcore system (and use it for heavy processing tasks), so I probably notice those limitations more then you would on a typical system. I also had a first generation SSHD before it started failing at 10k hours so that also plays a role in my dislike for SSHDs. They're fine for typical use cases, but they have severe limitations.
Yes it's an older system but it's not completely obsolete yet. It's near the end but not quite there yet.
完成的
I stand corrected :-(. I had a 3rd gen but that doesn't change how disappointing it was.
完成的
添加一条评论
添加你的答案
Mad 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 5
总计 115
