FAN is running at high speed when off or in sleep mode.
A problem with a 2012 21,5” iMac. If it’s off or in sleep mode the fan is spinning at high speed. iMac is working quite well, even the fan doesn't behave strange as along as the computer is running. But it becomes strange when I shut down (or sleep mode) the Mac, because when the machine is OFF, the fan runs riot.
The fan stops only in this two cases:
- I physically disconnect the power cable. After doing so, I can wait as long as I want (I tried 8 hours during night). In the very moment when I reconnect the power supply, the fan instantly starts running at top speed and won't stop again (I lost patience after 20 minutes and then I pulled out the plug again).
- I press the on/off-button on the back of the lower left corner of the Mac. In this case the fan stops on the spot and the startup-procedure beginns and everything is fine.
Tried all the SMC and NVRAM resets and disconnected the harddrive when it was open, but nothing helps.
Does anyone know what this problem is? Maybe a faulty sensor on the logicboard?
10条评论
Did you change the hard drive?
由 mayer 完成的
Yes. I disconnected the SATA and turned it on. The fan blowed immediately 100% when the plug was attached.
由 Machiel van der Plas 完成的
The systems fan appears to be working correctly. Can you clarify what you are trying to do here are when you suspect the problem is happening.
由 Dan 完成的
Yes unplugged the hard drive and installed a new one, still same problem.
I would install TG Pro and post a snapshot of it here. Who's drive did you install?
由 Dan 完成的
显示更多的5条评论
