跳转到主内容
15" laptop manufactured by Dell at the end of 2016. The laptop is very configurable, uses 7th generation processors and has a grey plastic chassis.
How can I remove a stripped screw?
I was trying to remove the screw to get into the laptop and ended up stripping the screw. Any idea how I can take it out?? I've tried using superglue, didn’t work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
you can make a small groove at one side like the photo
这个答案有帮助吗?
得分 1
添加一条评论
Here’s the iFixit Guide on stripped Screw Removal:
如何卸下滑丝的螺丝
这个答案有帮助吗?
得分 1
添加一条评论
Their is a special bit/tool that can remove stripped screw heads but cannot recall it’s name!…This problem can occur when the wrong screw driver is used to remove Philips/ Pozidrive type drivers but especially when the tool is not a snug fit and plumb with respect to the screw.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sabeel Hussain 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 835
